I have 2 layers. Layer 1 has Geographic Coordinate System: WGS 84 and Datum: WGS_1984. Layer 2 has Geographic Coordinate System: WGS_1984 and datum WGS_1984. In order to clip these layers, apparently they need to have the same coordinate system. So, I used the "Projections and Transformations" tool in the ArcToolbox to transform the 1st layer's coordinates to WGS_1984. There is a drop down list that you can choose which Geographic Transformation you would like to apply. When I click on the drop down, it provides no options for transformations. If I skip this step and press "OK," the transformation to WGS_1984 fails with the following errors (screenshot attached). What do I need to do to make this transformation so I can finally clip the layers?
