ArcGIS Server / Portal 10.4.1
I am using a federated Portal/Server site. I installed a VPN server on the machine to be able to remote in. When I restarted the server, ArcGIS Portal and Server pull the IP address from the VPN server instead of the local machine. Is there a way to manually force the web adaptor to use the local IP?
I already tried going through IIS and setting the website binding IP and host name instead of using all available IPs.
I disabled the VPN adaptor as well but it still pulled the IP from it. I made sure the service was off.
I restarted ArcGIS Server and Portal after each. Do I need to reboot the machine instead?
