Run PyScripter with ArcGIS Pro's Python 3.x and the ArcGIS API for Python
16835
9
04-27-2017 12:17 PM
This document will show you how you can setup PyScripter to run ArcGIS Pro's Python 3.x version and the ArcGIS API for Python
Note:  the easiest way to install the ArcGIS API for Python is to install ArcGIS Pro.  ArcGIS Pro 1.4 and later gives you a Python Package Manager interface that can be used to download and install the ArcGIS API for Python.  See the following link for more details on how to install the API:
Install and set up | ArcGIS for Developers
On the server where ArcGIS Pro is installed, follow the below steps to utilize it with PyScripter:
1.  Download and install the 64-bit version of PyScripter
2.  Open PyScripter and click View > Toolbars > View Toolbar:
3.  On the View Toolbar, click the Python Versions tool (first icon):
4.  Select the option Setup Python Versions
5.  Select the green + (Add a new Python version)
6.  Browse to the directory where the python.exe for ArcGIS Pro resides.  Ex:
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3
4. Click OK
5. The Conda 3.x should be listed under Unregistered Versions:
6.  To switch to Conda 3.x, click the Python Versions tool and select the newly added version:
You have the ability to easily switch back and forth between environments.
As a test, you can use the following snippet to test the new python environment is working successfully:
from arcgis.gis import GIS
gis = GIS() # anonymous connection to www.arcgis.com
# Search for 'USA major cities' feature layer collection
search_results = gis.content.search('title: USA Major Cities and owner:esri','Feature Layer')
# Access the first Item that's returned
major_cities_item = search_results[0]
print(major_cities_item)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Comments
RoySP
Can you also post something for PyCharm?
JakeSkinner
Esri Esteemed Contributor
Roy SP‌ take a look at the bottom of this document for PyCharm:
https://community.esri.com/docs/DOC-8359
RoySP
Great, Thank you!
gisadminCPG
How would I do this if I wanted to set up a scheduled task that worked with the external run?
JakeSkinner
gisadmin CPG‌ you could run this as a .bat file on a machine that has ArcGIS Pro installed.  For example, you can access 64-bit python from the following location on a server that has Pro installed:
You could set up your .bat file like the following:
cd C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3
python <path to script>\Script.py
Then have Windows Task Scheduler execute the .bat file
DuncanHornby
MVP Notable Contributor
FYI,
I stumbled across this post and failed to get pyscripter working with ArcPro python. It is because I have installed the 32 bit version of pyscripter. I felt it worth mentioning for others. One must have the 64 bit version of pyscripter installed to be able to use the ArcPro python. Still this was a really helpful document, thanks!
JakeSkinner
Thanks, Duncan Hornby‌.  I went ahead and updated the document stating you will need to download the 64-bit version of PyScripter.
BruceWilliams1
Occasional Explorer
@JakeSkinner May I ask that you make a change to your document?
On Step 6. Browse to the directory where the python.exe for ArcGIS Pro resides.
Ex: C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\python.exe
(would you remove the \python.exe since we are looking for the directory - this catches me every time I need to reload PyScripter)
I also had a problem with Python 2.7 not showing in the Registered Versions and I had to click on a button to get PyScripter to work without it, but I don't know what button it was. If anyone else has this issue please post it here.
Thanks for the post!!!
PriscillaThoopthong
I'm trying to install the latest conda version (3.7)  in PyScripter and when I activate it just hangs.  Any idea?
Version history
Last update:
‎02-10-2021 11:56 AM
Updated by:
Contributors
