ChartJS Widget v1.2 06/18/2018
160178
03-25-2018 09:24 AM
Hi all,
Simply share this ChartJS Widget with you.
Chart.js is a community maintained open-source library that helps you easily visualize data using JavaScript. Display line and bar charts using your ArcGIS GeoServices.
The Web App Builder 'dashboard' theme allows you to create graphics and filter them automatically when the map extension changes. The following widget that I created allows, in addition to this (line and vertical bar chart), to select any layer of the Web Map. Dojo class of ChartJS created, the creation of any type of graphic that the library allows is simple in this way.
Remember: Add ChartJS dependencies. How?
Demo
My GitHub
I build Esri widgets without any -economic- interest, if you find it useful for your projects, you can buy me a coffee
https://ko-fi.com/adrisolid
Don't hesitate to contact me if you need some custom developments: [email protected]
Cheers!
Comments
RebeccaStrauch__GISP
LanceKirby2
Love it!
Version history
Last update:
‎03-25-2018 09:24 AM
Updated by:
Contributors
