I was wondering if you can pre-define parcel edge info? I understand parcel edges are being defined in scenarios, which makes sense as developing plausible buildings would only be in a scenario, but wanted to know if there was a way of having the parcel edges pre-defined so that plausible buildings would be generated without modifications to the parcel edges as they are unlikely to be manipulated in reality from the existing situation. I tried accessing the parcel edges in the database but you can only see as is (no defined edges) and could not find anywhere how the schema is set up after defining scenario based parcels so that I could define for existing conditions.
Thank you!
Brian
