How to set the filter properties to filter records with certain values? I need to filter records with its ID containing a certain value such as "_boat". The filter operator doesn't have "like" or "contain".
Hi Hwa Saup Lee,
Once you have configured your input connector and geoevent definition you are able to establish a geoevent processor. Within this processor you can add an attribute filter (Attribute filters—Process Event Data(10.7.1) | Documentation for ArcGIS Enterprise ) with a number of supported operators. Depending on what you require this for you can also look into Incident detector or several other options , see Incident Detector Processor—Process Event Data(10.7.1) | Documentation for ArcGIS Enterprise.
You can then configure this with the geoevent output destination and type you are after.
Shane
Hi. Shane, I tried with the attribute filter however cannot find a way to filter record including certain values in the string.
For example, I need:
UID like '%Vessel%'
