When clicking on the Selected features in the list ( from Select Widget), a popup opens to the feature but no attributes of the feature are shown on the pop up and I see an error in the Console. Anyone else seeing this issue?
I'm using WAB Developer 2.7 and still not getting anything in my pop-up when using the select widget.
I checked the bug's status today and it's on "implemented".
So I tried again as described in my post written in january and now it works. The pop-up is no longer empty. It now uses the pop-up configuration set in the web map.
Thanks for fixing!
Hi WebGIS Gdibx,
First, wow - nice app! The cartography looks really good! Any chance I could get your permission to add this app to the Web AppBuilder live sites showcase? If so, can you please send me an email: dlaw@esri.com so we can discuss further.
Second, thanks for describing your issue. Yes, I can confirm that we've identified this as a bug:
> BUG-000107579 The Select widget in Web AppBuilder for ArcGIS displays a blank pop-up for a selected feature of map image layers
We are currently working to address this.
Hope this helps,
Hi Derek,
we have an application for our city map (Stadtplan Leipzig) and there are Pop-ups configured in the web map for every layer. For example the resident services offices ("Bürgerämter").
I tried to implement the "select widget" in WAB in ArcGIS Online (in a copy of the App for testing) and it finds the features and shows them in the results list.
But when I click on the result, there is just an empty pop-up shown and not the configured one that comes up when I click the regular symbol in the map.
Thanks for your help.
I was unable to reproduce the error reported by Sowjanya back in early 2017.
Tom's post in Oct 2017 was related to custom functionality, which can't really be called a "bug" because of his customization(s).
Could you please provide some context/info describing your issue, including detailed steps to reproduce.
Is there allready a Bug logged in the ArcGIS Technical Support? I am having the same problem using the WAB implemented in ArcGIS Online and am considering to ask our support partner. But that doesn't make sense when it's a "known bug".
I'm having this problem too. I am using the developer edition of WAB 2.5.
On mapLoad I require in a custom javascript module that adds a FeatureLayer (pointing to MapService layer hosted on an ArcGIS Server instance in my data center, not AGOL) to the map. This all works great, features draw on the map, I have added a mouse-over event listener on the layer that opens the map.infoWindow popup when a layer graphic is hovered over - all works great. Except the console keeps showing the "Cannot read property 'parentNode' of null .... " whenever a hover on a graphic from the FeatureLayer occurs.
Thanks dlaw-esristaff
Hi Sowjanya,
I am not able to reproduce your error. I retested with Web AppBuilder Developer Edition v2.3 with Portal for ArcGIS 10.4.1. Please contact Esri Tech Support and provide them with detailed steps and sample data so they can try to reproduce your issue.
Derek Law - This is with developer edition WAB 2.3 for Portal. The deployed app is not displaying the attributes ( from Select Widget). Any chance you see this on your end?
Hi Derek- Thanks for your reply. Yes, this bug occurs when adding layers via a custom widget in 2.3.
I am not able to reproduce your error. I'm using Web AppBuilder embedded within ArcGIS Online. Can you share the REST URL to your web service?
Hi Phil,
Not sure what you mean when you say "... occurs on layers that are added to the map programatically ...", like within a custom widget?
If you think the behavior you're seeing in Web AppBuilder Developer Edition v2.3 is a bug - please open an incident with Esri Tech Support so we can get some repro steps to investigate further.
I am seeing this in builder version 2.3 but not 2.2. This occurs on layers that are added to the map programatically, but not on layers that are referenced in an AGOL hosted web map. I'd call this a bug.
Error:Uncaught TypeError: Cannot read property 'parentNode' of null at Object.b.place (init.js:206) at Object.<anonymous> (RelatedRecordsPopupProjector.js?wab_dv=2.3:498)
https://community.esri.com/migrated-users/3176
