Hello esri community,
Just about everyday I get a phone call from the Application user/product builder that they are unable to publish new products and cannot validate the Datastore.
I log into the Database server and run the describedatastore.bat tool and receive this error:
Error encountered: No valid connection to ArcGIS Data Store configuration store established.
Caused by: Connection to localhost:9876 refused. Check that the hostname and port are correct and that the postmaster is accepting TCP/IP connections.
The only workaround has been to manually stop and start the ArcGIS Datastore service or reboot the entire server. Has anyone encountered this? Any luck with a permanent solution?
Things I have done:
1. Verified the service account running the ArcGIS Datastore server has full rights to
C:\arcgisdatastore
C:\Program Files\ArcGIS\DataStore
2. Verified Host Based Security System/firewall is not blocking a connection
