Dear all,
In ArcGIS Pro I can create a map that uses MapLex labeling to create Composite Callouts with leader lines that have a symbol (see file attached).
According to https://enterprise.arcgis.com/en/server/latest/publish-services/windows/supported-functionality-in-map-services.htm MapLex labeling is supported on ArcGIS Server:
The Standard Label Engine is available, as well as annotation. The Maplex Label Engine is available but is recommended for cached maps only.
But when I publish my map from ArcGIS Pro as a Web Layer, the result is an unsupported layer in the resulting service.
In the past it was possible to publish using MapLex labeling from ArcMap. There was a warning, but you could proceed.
Is there more information on this issue? Why doesn't it work? Is it foreseen in the future?
Many thanks in advance...
