There is an ArcObjects application opens an mxd file which has a layer using an ArcGIS Server cached MapService and another layer from a geodatabase. The application exports mxd as pdf file. Sometimes application pops up a dialog as attached, and waits for the response. Is there a way to prevent the popup?
All ArcGIS products versions are 10.2.1.
Hello @HikmetBiyikoglu,
Are you able to update the .mxd to consume the cached map service over 'HTTPS' instead of 'HTTP'? Then retest your application is the ArcGIS Server service secured?
Thomas
Hi @ThomasJones1
Thanks for your reply. No, ArcGIS Server service is not cofigured as secured. Do we have to configure it as secured to fix the problem?
Hikmet
