ArcGIS Pro 2.8.4: An option to display the Pro version (release) in the title bar,
It would be great if an option to display the Pro version (release) in the title bar is made available
Jamal432@gmail.com NEOMAPPER and rawansaleh
Can you please add some detail about why this is needed in the title bar as opposed to in the backstage About section? Is there a need to immediately see the version while you're working in a project without going to the backstage? Details would be helpful. Thank you!
The question should be why not? title bar area is not busy and can take this.
For example, in AutoCAD the version in addition to file path can be shown there to know where we are.
I guess my initial thinking about why not might be that we would want to be conservative with adding content to the title bar (note that I'm not a decision maker in this process). How does having the AutoCAD version in the title bar contribute to your work? How does it add value to your workflows? How do you use it?
Please don't interpret this as being pedantic. If we don't have this info, it could be likely that nothing happens with this idea, whereas if there is a compelling reason for adding this, it might be an easier story to convey to development.
Thanks!
Well…at our work environment, we do use screenshots when report issues. Basic question like which version we use is very common. This could be eliminated by this.
Second, we do also take screenshots in order to document steps to perform some work. After years, we got lost when we follow these screenshots as they refer to different version (10.1, 10.2, 10.3, 10.4, 10.5, 10.5.1, 10.6). Showing the version resolves such confusion.
These are just few examples! But I see no one single disadvantage for displaying the version. Is there any?
ArcGIS Pro 2.7.2: Displaying the version (release) and aprx file path in the title bar,
It would be great if the ArcGIS Pro is enhanced to be able to display the version (release) and aprx file path in the title bar. These options are already available in AutoCAD, for example.
This is important to know where we are!
duplicate of
ArcPro 2.4.2: The version of the Pro is not displa... - Esri Community
Hey @JamalNUMAN a notification test on your idea
I didn’t receive an e-mail notification for the first comment but I did for the second one. I think that the reason is the setting that’s marked below
There is no settings related to receive an e-mail notification as a comment is added to an idea
Hi @JamalNUMAN I merged your new idea with your existing idea. The part about displaying path you already submitted as https://community.esri.com/t5/arcgis-pro-ideas/arcpro-2-4-2-how-to-display-the-full-path-of-the-aprx-file-on/idc-p/1038562
Please remember to search for existing ideas before posting new ideas. Posting duplicate ideas only creates additional work for moderators and it may result in votes getting split across more than one.
This and other best practices for working with ideas is covered in ArcGIS Ideas Submission Guidelines and Statuses
Thank you!
Hi Kory,
Right, but it happens to forget that I have already suggested particular idea. It would be great if the idea section is enhanced to bring up a list for all similar ideas as the title is typed. This feature is already available in FME forum. This will minimize posting similar ideas
That functionality is already in place when posting a new idea:
I’m not sure why simple option like this one should take this much of time. I would appreciate if it could be considered in the near future to eliminate any confusion when using the Pro
Melden Sie sich an, um zu posten, Inhalte zu folgen und mehr. Neu hier? Kostenlos registrieren.
