how I can print my survey123 form if I decided to use paper version of survey?
Hi Juma,
Are you wanting to print a blank copy of your survey (with questions only) for paper data entry use?
We do not currently support this via Connect or Web Designer, however you could create a custom report template via the survey123 website without any values and print that in the format you require for paper based collection, that can then be manually input via the app at a later date.
Phil.
Hi Phil,
Thanks. I tried and cant manged any proper instruction I can follow?
Thanks.
Juma
Please take a look at the Survey123 Online Documentation here: Print survey results—Survey123 for ArcGIS | ArcGIS
And the following blog may be helpful also: https://community.esri.com/groups/survey123/blog/2017/07/26/introducing-custom-form-report-templates-in-survey123-for-arcgis
Hi Philip help please. I want to export my survey data to CSV file but want to see numerac value rather text. for example intead of Yes or No I want to see 1 or 2 ? How I can do ythis/
The export function available in the Survey123 website will export the values as they are stored in the table - it does not support any transformation of the data as part of the export. You would need to have a process that changes the values (such as a python script) after the export.
