I have created a tile package and loaded it into the map folder on my device but Survey123 is still using the ESRI basemap and not my customer basemap
Hi Jason,
Have you followed all the steps outlined here: https://doc.arcgis.com/en/survey123/desktop/create-surveys/preparebasemaps.htm
How did you create the .tpk file and how big is the file? What sort of devices are you using, please provide the make/model and OS version, and also what app version you are using?
Phil.
Hi Philip
I did but the instructions were not clear on copying the snipet of code into my existing .info – step 3
Copy the following code snippet into this file, modifying the map sources section with your own shared tile package name and URL, and click Save. This snippet should be placed within the first layer of brackets in MySurvey.info.
Regards
Jason Catlin
Here is a copy of the info file once it was configured in Connect for Survey123
"displayInfo": {
"map": {
"coordinateFormat": null,
"defaultType": {
"name": "sweepbase3"
"home": {
"latitude": -37.830643,
"longitude": 144.96552,
"zoomLevel": 9
"preview": {
"zoomLevel": null
"style": {
"backgroundColor": null,
"backgroundImage": null,
"inputBackgroundColor": null,
"inputTextColor": null,
"textColor": null,
"toolbarBackgroundColor": null,
"toolbarTextColor": null
"imagesInfo": {
"captureResolution": 640
"publishInfo": {
"connectVersion": "3.3.51",
"webFormTransform": true
"queryInfo": {
"applySpatialFilter": true,
"mode": "",
"where": ""
"sentInfo": {
"enabled": true
"serviceInfo": null
0407048458
Jason.catlin@broadspectrum.com
Ten Rivers
You do not need to follow the shared tile package steps if you are not using a shared tpk that has been shared via your AGO org as an item. If you are simply copying the tpk to the maps folder via a browser or using the new file path chooser in the app Settings -> Storage to select a different folder on a SD card for example, then all the surveys should be able to view this tpk.
If you still can not see the tpk can you provide more info about the size, type, how you created it, os/device etc?
You wont see the default ESRI maps in the Maps folder that you load your .tpk files to, something like "C:\Users\UserName\ArcGIS\My Surveys\Maps". Once your tpk is in here it should then appear in Survey Connect Settings where you can select your default base map "Settings\Map\Default Map Type". Once you change the default map, the INFO file within your survey design folder will update accordingly and this will become your default map when the survey gets published.
I have this same problem. Survey123 Connect won't recognize the new basemap tpk. I've tried every method - tpk in the maps and media folders, online, modified the .info file.
Tools:
Survey123 Connect 3.3.51Tile Package Kreator 1.3.30Windows 10 x64 Enterprise 1803tpk file size 5.6 MB
