I've noticed that the link to the survey service doesn't open the service page properly. The page displays Token required message and doesn't show service info. Is it ok?
Hi Annastaysia
The Connect link will take you to the form item online. You would be prompted to sign into ArcGIS Online to access it (if it is secured) and then you should be able to follow the links to the layer, and then feature service url:
As long as you are signed into to ArcGIS online, you should not be prompted for a token.
Thanks
John
I'm signed in to ArcGIS Online. So, that means this is a bug?
Can you confirm that there is a token at the end of the url you are using to access the service, e.g
//services5.arcgis.com/jMCHJcLe13FaKCFB/arcgis/rest/services/service_a596f962b6b94c07b0ffc58430c1bd29/FeatureServer?token=HIkrzVFWfjdk............
There is no token at the end of the link/ And it's the problem.
https://services.arcgis.com/HOo89W8RWwrXP286/arcgis/rest/services/service_d32a761958234f0a8b757e03f472f615/FeatureServer
