My customer would like to add pictures taken from him underground camera onto the data record that is stored on Survey123 in AGOL. How can this be done?
Assuming you are offline.
A lot of these cameras have Bluetooth now. You could Bluetooth file transfer to the tablet.
Maybe you are lucky and the camera uses a SDCard and you have a Samsung with a SDCard reader built in. If not you can also buy external SDCard readers for tablets.
There is a slight chance you can use the camera cable and plug into the tablet.
If the tablet has a cell card and the camera has WiFi you could turn the tablet into a hotspot and connect to it.
Hope that helps.
Thanks, Doug, for this prompt and helpful response!
How can this be accomplished in the AGOL environment which hosts the data records gathered using Survey123 app in the field?
Depends if you want it in the same record as the Survey123 form. Add a Photo question to the form. When filling out the survey just leave it blank. Then later the user could plug the camera in to the computer. Go into a AGOL web map that has the Survey123 Feature Service in. Click to get the popup of the feature then click Edit. You will see a Add Attachment at the bottom. Add it there. All Survey123 does is enable attachments on the FS - then you can use it anywhere just like regular attachments.
You can also have a separate FC just for photos.
Thanks, Doug. You're amazing, with your lightning-fast response!
What is FS and FC, by the way?
