I'm running into an issue submitting a survey from the Windows survey123 app.
The FeatureService powering the survey is a ArcGIS Server service that has been added to arcgis online. The logfiles and the hanging message show that the error occurs on a layer that doesn't even participate in the survey.
The relevant error message shows:
<15>1 2019-03-11T18:17:20Z WSBLT-683 Survey123forArcGIS 14156 - [AppStudio@11205 category="qml" function="getNext" filename="XFormFeatureService.qml" line="994"] qml: Requesting layerInfo: https://utility.arcgis.com/usrsvcs/servers/.../pipeline_inspections/FeatureServer/28
<15>1 2019-03-11T18:17:20Z WSBLT-683 Survey123forArcGIS 14156 - [AppStudio@11205 category="qml" function="addLayerInfo" filename="XFormFeatureService.qml" line="1022"] qml: Feature layerInfo: {
"advancedQueryCapabilities": {
"supportsDistinct": true,
"supportsOrderBy": true,
"supportsPagination": true,
"supportsQueryWithDistance": true,
"supportsReturningQueryExtent": true,
"supportsSqlExpression": true,
"supportsStatistics": true,
"supportsTrueCurve": true
"archivingInfo": {
"startArchivingMoment": 1551457550000,
"supportsQueryWithHistoricMoment": true
"capabilities": "Create,Query,Update,Delete,Uploads,Editing",
"copyrightText": "",
"currentVersion": 10.51,
"dateFieldsTimeReference": {
"respectsDaylightSaving": false,
"timeZone": "UTC"
"description": "",
"displayField": "contractorname",
"editFieldsInfo": null,
"fields": [
"alias": "objectid",
"editable": false,
"name": "objectid",
"nullable": false,
"type": "esriFieldTypeOID"
"alias": "Service Type",
"editable": true,
"length": 255,
"name": "servicetype",
"nullable": true,
"type": "esriFieldTypeString"
"alias": "Any route obstructions",
"editable": true,
"length": 255,
"name": "routeobstruct",
"nullable": true,
"alias": "Locates Marked",
"editable": true,
"length": 255,
"name": "locatemarked",
"nullable": true,
"alias": "Electric Meter installed",
"editable": true,
"length": 255,
"name": "electricmeter",
"nullable": true,
"alias": "Gas Meter Location marked",
"editable": true,
"length": 255,
"name": "gasmetermarked",
"nullable": true,
"alias": "Site is to grade",
"editable": true,
"length": 255,
"name": "sitegrade",
"nullable": true,
"alias": "Sewer Cleared",
"editable": true,
"length": 255,
"name": "sewerclear",
"nullable": true,
"alias": "Route flagged",
"editable": true,
"length": 255,
"name": "routeflag",
"nullable": true,
"alias": "Contractor name",
"editable": true,
"length": 255,
"name": "contractorname",
"nullable": true,
"alias": "Backbone service",
"editable": true,
"length": 255,
"name": "backboneservice",
"nullable": true,
"alias": "Inservice date",
"editable": true,
"length": 8,
"name": "inservicedate",
"nullable": true,
"type": "esriFieldTypeDate"
"alias": "Completion date",
"editable": true,
"length": 255,
"name": "completiondate",
"nullable": true,
"alias": "Gas Workorder Number",
"editable": true,
"length": 255,
"name": "gasworknumber",
"nullable": true,
"alias": "Electric Workorder Number",
"editable": true,
"length": 255,
"name": "electricworknumber",
"nullable": true,
"alias": "Main workorder number",
"editable": true,
"length": 255,
"name": "mainworknumber",
"nullable": true,
"alias": "globalid",
"editable": false,
"length": 38,
"name": "globalid",
"nullable": false,
"type": "esriFieldTypeGlobalID"
"alias": "Site Check ID",
"editable": true,
"length": 38,
"name": "sitecheckglobalid_service",
"nullable": true,
"type": "esriFieldTypeGUID"
"globalIdField": "globalid",
"hasAttachments": false,
"htmlPopupType": "esriServerHTMLPopupTypeNone",
"id": 28,
"isDataVersioned": false,
"maxRecordCount": 1000,
"name": "NewService",
"objectIdField": "objectid",
"ownershipBasedAccessControlForFeatures": null,
"relationships": [],
"subtypeField": "",
"supportedQueryFormats": "JSON, AMF, geoJSON",
"supportsAdvancedQueries": true,
"supportsApplyEditsWithGlobalIds": true,
"supportsCalculate": false,
"supportsRollbackOnFailureParameter": true,
"supportsValidateSQL": true,
"syncCanReturnChanges": true,
"type": "Table",
"typeIdField": "",
"types": [],
"useStandardizedQueries": true,
"parentRelationships": [],
"childRelationships": []
<15>1 2019-03-11T18:17:20Z WSBLT-683 Survey123forArcGIS 14156 - [AppStudio@11205 category="qml" function="updateRelationships" filename="XFormFeatureService.qml" line="1180"] qml: Updating relationship for: Inspection
<12>1 2019-03-11T18:17:20Z WSBLT-683 Survey123forArcGIS 14156 - [AppStudio@11205 category="default" filename="XFormFeatureService.qml" line="1180"] qrc:/qml/XForms/XFormFeatureService.qml:1180: TypeError: Cannot read property 'name' of undefined
<15>1 2019-03-11T18:17:22Z WSBLT-683 Survey123forArcGIS 14156 - [AppStudio@11205 category="qml" function="expression for onStateChanged" filename="Portal.qml"<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Looks like the relevant line in survey123 is:
Update: I did a little more digging and found a different version of survey123 that shows the error. Looks like the issue is caused when there is a table that participates in a relationship with another layer in the feature service in the table, but does not participate in a relationship with the main layer. cc James Tedrick
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">updateRelationships</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">updateChildRelationship</SPAN><SPAN class="punctuation token">(</SPAN>childLayerInfo<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>XFormJS<SPAN class="punctuation token">.</SPAN><SPAN class="token function">isNullOrUndefined</SPAN><SPAN class="punctuation token">(</SPAN>childLayerInfo<SPAN class="punctuation token">.</SPAN>relationships<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN>
<SPAN class="keyword token">var</SPAN> childRelationship<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> i <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> i <SPAN class="operator token"><</SPAN> childLayerInfo<SPAN class="punctuation token">.</SPAN>relationships<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> relationship <SPAN class="operator token">=</SPAN> childLayerInfo<SPAN class="punctuation token">.</SPAN>relationships<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>relationship<SPAN class="punctuation token">.</SPAN>cardinality <SPAN class="operator token">===</SPAN> <SPAN class="string token">"esriRelCardinalityOneToMany"</SPAN> <SPAN class="operator token">&&</SPAN>
relationship<SPAN class="punctuation token">.</SPAN>role <SPAN class="operator token">===</SPAN> <SPAN class="string token">"esriRelRoleDestination"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
childRelationship <SPAN class="operator token">=</SPAN> relationship<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">break</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>childRelationship<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> childKeyField <SPAN class="operator token">=</SPAN> <SPAN class="token function">findField</SPAN><SPAN class="punctuation token">(</SPAN>childLayerInfo<SPAN class="punctuation token">,</SPAN> childRelationship<SPAN class="punctuation token">.</SPAN>keyField<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>childKeyField<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">error</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Child keyField not found:"</SPAN><SPAN class="punctuation token">,</SPAN> childRelationship<SPAN class="punctuation token">.</SPAN>keyField<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>childKeyField<SPAN class="punctuation token">.</SPAN>type <SPAN class="operator token">!==</SPAN> <SPAN class="string token">"esriFieldTypeGUID"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">error</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Unsupported childKeyField type:"</SPAN><SPAN class="punctuation token">,</SPAN> childKeyField<SPAN class="punctuation token">.</SPAN>type<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
childRelationship<SPAN class="punctuation token">.</SPAN>keyFieldInfo <SPAN class="operator token">=</SPAN> childKeyField<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> parentLayerInfo <SPAN class="operator token">=</SPAN> layerInfos<SPAN class="punctuation token">[</SPAN>childRelationship<SPAN class="punctuation token">.</SPAN>relatedTableId<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>parentLayerInfo<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> parentRelationship<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN>i <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> i <SPAN class="operator token"><</SPAN> parentLayerInfo<SPAN class="punctuation token">.</SPAN>relationships<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
relationship <SPAN class="operator token">=</SPAN> parentLayerInfo<SPAN class="punctuation token">.</SPAN>relationships<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>relationship<SPAN class="punctuation token">.</SPAN>id <SPAN class="operator token">===</SPAN> childRelationship<SPAN class="punctuation token">.</SPAN>id<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
relationship<SPAN class="punctuation token">.</SPAN>role <SPAN class="operator token">===</SPAN> <SPAN class="string token">"esriRelRoleOrigin"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
parentRelationship <SPAN class="operator token">=</SPAN> relationship<SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"relationship:"</SPAN><SPAN class="punctuation token">,</SPAN> parentRelationship<SPAN class="punctuation token">.</SPAN>id<SPAN class="punctuation token">,</SPAN> parentRelationship<SPAN class="punctuation token">.</SPAN>name<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"<==>"</SPAN><SPAN class="punctuation token">,</SPAN> childRelationship<SPAN class="punctuation token">.</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>parentRelationship<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> parentKeyField <SPAN class="operator token">=</SPAN> <SPAN class="token function">findField</SPAN><SPAN class="punctuation token">(</SPAN>parentLayerInfo<SPAN class="punctuation token">,</SPAN> parentRelationship<SPAN class="punctuation token">.</SPAN>keyField<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">!</SPAN>parentKeyField<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">error</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Parent keyField not found:"</SPAN><SPAN class="punctuation token">,</SPAN> parentRelationship<SPAN class="punctuation token">.</SPAN>keyField<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>parentKeyField<SPAN class="punctuation token">.</SPAN>type <SPAN class="operator token">!==</SPAN> <SPAN class="string token">"esriFieldTypeGUID"</SPAN> <SPAN class="operator token">&&</SPAN> parentKeyField<SPAN class="punctuation token">.</SPAN>type <SPAN class="operator token">!==</SPAN> <SPAN class="string token">"esriFieldTypeGlobalID"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">error</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Unsupported parentKeyField type:"</SPAN><SPAN class="punctuation token">,</SPAN> parentKeyField<SPAN class="punctuation token">.</SPAN>type<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>parentKeyField<SPAN class="punctuation token">.</SPAN>type <SPAN class="operator token">===</SPAN> <SPAN class="string token">"esriFieldTypeGlobalID"</SPAN> <SPAN class="operator token">&&</SPAN> <SPAN class="operator token">!</SPAN>featureServiceInfo<SPAN class="punctuation token">.</SPAN>supportsApplyEditsWithGlobalIds<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">error</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Feature service requires supportsApplyEditsWithGlobalIds for parent keyField type:"</SPAN><SPAN class="punctuation token">,</SPAN> parentKeyField<SPAN class="punctuation token">.</SPAN>type<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
parentRelationship<SPAN class="punctuation token">.</SPAN>keyFieldInfo <SPAN class="operator token">=</SPAN> parentKeyField<SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"child name:"</SPAN><SPAN class="punctuation token">,</SPAN> childLayerInfo<SPAN class="punctuation token">.</SPAN>name<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"childRelationship:"</SPAN><SPAN class="punctuation token">,</SPAN> JSON<SPAN class="punctuation token">.</SPAN><SPAN class="token function">stringify</SPAN><SPAN class="punctuation token">(</SPAN>childRelationship<SPAN class="punctuation token">,</SPAN> undefined<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"parent name:"</SPAN><SPAN class="punctuation token">,</SPAN> parentLayerInfo<SPAN class="punctuation token">.</SPAN>name<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"parentRelationship:"</SPAN><SPAN class="punctuation token">,</SPAN> JSON<SPAN class="punctuation token">.</SPAN><SPAN class="token function">stringify</SPAN><SPAN class="punctuation token">(</SPAN>parentRelationship<SPAN class="punctuation token">,</SPAN> undefined<SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
childLayerInfo<SPAN class="punctuation token">.</SPAN>parentRelationships<SPAN class="punctuation token">[</SPAN>parentLayerInfo<SPAN class="punctuation token">.</SPAN>name<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> childRelationship<SPAN class="punctuation token">;</SPAN>
parentLayerInfo<SPAN class="punctuation token">.</SPAN>childRelationships<SPAN class="punctuation token">[</SPAN>childLayerInfo<SPAN class="punctuation token">.</SPAN>name<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> parentRelationship<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>parentKeyField<SPAN class="punctuation token">.</SPAN>type <SPAN class="operator token">===</SPAN> <SPAN class="string token">"esriFieldTypeGlobalID"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
useGlobalIds <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">for</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">var</SPAN> i <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> i <SPAN class="operator token"><</SPAN> layerInfos<SPAN class="punctuation token">.</SPAN>length<SPAN class="punctuation token">;</SPAN> i<SPAN class="operator token">++</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">var</SPAN> layerInfo <SPAN class="operator token">=</SPAN> layerInfos<SPAN class="punctuation token">[</SPAN>i<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"Updating relationship for:"</SPAN><SPAN class="punctuation token">,</SPAN> layerInfo<SPAN class="punctuation token">.</SPAN>name<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">updateChildRelationship</SPAN><SPAN class="punctuation token">(</SPAN>layerInfo<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
