Is it possible to manually enter coordinates using the DMS format within the map? The settings for the survey are set to DMS and the coordinates in the bottom left corner of the map display in DMS when viewing the map. However, when you select them to manually change the coordinates, the format reverts back to DD.
Is this a bug or does Survey123 not yet support entering coordinates in DMS? I'd appreciate any feedback, thanks!
Hi Emily,
This currently isn't possible; that being said, alternate coordinate format entry is an area we're actively developing and are working to support.
Thank you for your reply, that's what I needed to know!
