Because under the type column,there are a variety of options,may be it reside inhere,kindly reply
.Thank you
You might want to move your thread to https://community.esri.com/groups/survey123?sr=search&searchId=f2531e89-5079-4608-96ab-9866461a28f5&searchIndex=0 since the GeoNet Lounge isn't the best place to post
A dropdown question is defined by a few properties:
- The type of the question is either select_one (single choice) or select_multiple (multiple choice)
- The appearance will be either minimal or autocomplete
- The acceptable answers will be listed in the choices worksheet
Take a look at the following help topics:
Question Types: XLSForm essentials—Survey123 for ArcGIS | ArcGIS
Appearance: Appearance—Survey123 for ArcGIS | ArcGIS
Choices: XLSForm essentials—Survey123 for ArcGIS | ArcGIS
You can also create a survey from the 'Appearance' sample form to see how a dropdown question is constructed.
Thank you,worked out for me
