I am continually receiving error 500 message when trying to publish my survey in Survey123 Connect. I have reviewed all the help suggestions I can find. Each section will publish on its own. When I combine them into one survey, they will not publish. Attached is the document I am working with.
First I am seeing some commas in your choice list. Can't have that. See the reference tab. I do not think you can use a period either. Also note select_one can have spaces but multiple cannot (major bummer).
Second I am seeing you use the same name for a list as the field itself. I have seen all kinds of weird issues doing this. I always add List to the end - so financeList for example.
Third I saw at least one bad font tag need /font at the end
<font size="1">This will become the unique identifier for the project. If it will be a yearly project (i.e. Maintenance) you will add the year to the project name so it will still be unique year to year<font>
I also have a feeling there are repeated field names in here.
All I see so far. Hope that does it.
HI Melanie,
The following question names are used multiple times in the form:
Normally, the XLS file will highlight duplicate names; it sounds like the process of copy/pasting may have interfered with the Excel data validation.
I make sure to always right click Paste Values or, like James said, the form gets all kinds of broken.
