Error 500
When nested repeats were removed, it published without an error. Repeats were nested 2-levels deep. Documentation says you can have any number of nested repeats. What gives? ~JP
Are you maybe still using a older Connect version?
Version 3.3.5.1.
Hi Jim,
This is an unusual error- based on the message and where it occurs in the publishing sequence it appears to be occurring during a set of operations that occur after the feature service is initially created (when the fields and related tables are added or when editor tracking is enabled). Can you share the XLSForm (if not publicly, please e-mail jtedrick AT Esri.com) so that we could attempt to reproduce?
James,
Were you able to identify what causes this error? We have some fairly complicated forms with nested repeats that have published successfully and suddenly after a handful of changes one of them it refuses to publish and provides this error. Our teams need to get in the field in a couple days, so we really need to get this resolved and any insight you can provide would be appreciated.
We were not able to resolve the issue. We ended up removing the nested repeats. I suspect changes to the S123 app will make it easier... maybe.
Hello,
Has the reason for this error been identified? I have a survey with repeats (not nested repeats). I added new fields to the form outside the repeat and tried to publish it. The initial publish didn't push through as it's been taking so long, so I force closed Survey123 Connect and tried to publish again but got this error.
Pat
We are also facing the same issue. Have you found any solution for this?
Thanks in advance
Any update to this Error?
