In the past I have used the pulldata function to access data from a csv file pulling from a specific record.....I was wondering if there is a way to use the pulldata function (or another way) to 'cycle' through a file of data for verification.
My use case is to be able to walk into a building - select the building entered and then cycle/scroll through all of the spaces in that building one by one (pulling 5+ fields of information) and check a box verified or not verified (with a list of reasons why). SO instead of having to type in room by room just having it scroll through the list of areas in that particular building which would save a lot of time.
Looking for ideas on how/if this might be able to be accomplished. Wondering if a repeat can be used with pulldata not repetitive questions.
Adam
