In one of the blogs the difficulty.svg was provided in a zip file. I was wondering if the vehicle damage svg and/or the human body svg could be provided as well? The blog with the sample svg was at; https://community.esri.com/groups/survey123/blog/2019/09/26/using-the-image-map-appearance-in-survey123
You can find all the .svg files used in the sample template by:
C:\Users\Name\ArcGIS\My Survey Designs\Form 1\Media
If this answer is helpful, please mark it as helpful. If this answer solved your question, please mark it as the answer to help others who have the same question.
Hello Jim,
I think you can create a new survey in Survey123 Connect using the Image-map sample. You will be able to find the svg files in the media folder.
Cheers,
Sun
Thanks. That was easy!
