I have upgraded ArcGIS Server 10.3.1 to 10.4 and facing issues with publishing map services with data stored in enterprise databases.
The server is hosted in Amazon AWS with following infrastructure and works fine:
Windows 2012 R2
Server 10.3.1
PostgreSQL 9.3 (in the same server - localhost) with SDE enabled
PostgreSQL as AWS RDS with SDE enabled
However, when the server upgraded to 10.4, the service with data in enterprise databases (both localhost and AWS RDS) which used to publish are no longer working. The error is
The ArcServer log file shows the following details
Error executing tool. PublishServiceDefinition Job ID: j5a9a52478ffc49d19328e5ceefbb609f : ERROR 001487: Failed to update the published service with the server-side data location. Please see the server's log for more details. ERROR 001369: Failed to create the service. Failed to execute (Publish Service Definition). System/PublishingTools.GPServer
Failed to create the service.: Updating the server connection string for layer sdedb1.web.%gwstatmaster_staging Events failed. Attempted connection string was ENCRYPTED_PASSWORD=00022e68334e624d44786b57627653553542393435702b3845413d3d2a00;SERVER=xyz.c11tt3rfoa7s.eu-west-1.rds.amazonaws.com;INSTANCE="DSID=a8960749-e49c-41db-a095-a8a257a693b4";DBCLIENT=postgresql;DB_CONNECTION_PROPERTIES=xyz.c11tt3rfoa7s.eu-west-1.rds.amazonaws.com;DATABASE=sdedb1;USER=web;VERSION=sde.DEFAULT;AUTHENTICATION_MODE=DBMS. Table name is sdedb1.web.%gwstatmaster_staging. Please verify the data exists on the server. System/PublishingTools.GPServer
If I uninstall 10.4 and reinstall 10.3.1 on the same server, everything back to normal and working fine.
Has anyone else experienced the same issue?
Thanks and any suggestions much appreciated
Thomas
