I am using "Repeats" in one of my surveys, which works fine.
The problem I'm having is that when I copy from my Sent box and try to edit it, any drop-downs in the Repeat section is grayed out and cannot be edited.
Anyone know why this is?
Hi John,
What version of Survey123 app are you using? Editing of repeats is supported in v2.4 onwards. Attachments are not supported yet but most other questions now are including select_one and select_multiple.
Regards,
Phil.
Hi Phil,
I am using 4.3. I can edit the text box data in the Repeat but any drop-downs are grayed out and am unable to change the data in the drop-down.
John
The latest version of Survey123 field app available in the app stores is 2.4.72? Not sure what 4.3 refers to?
As mentioned you should be able to edit select_one and select_multiple in repeats if using latest version.
