Any one with an idea of what causes the 'not fully configured' message and how to fix it
I have come across that message before when my service was stopped and not working. Does the service seem available in the web map?
Hi
This usually happens when the data is not shared with the user that is opening the dashboard.
If you created the OpsDash and everything was visible to you, make sure that the same data is also shared with this user.
Yes it is available....
I am the one who created this dashboard and what I am currently doing is to my contents and reach to the feature layer.... when i try to open the data table, I get a red error messagE
The only way for the table to open is to refresh the the web page several times
Please note that my internet is good
Can you attach a screenshot of the settings for the widgets? There may be an issue in the configuration of the elements
Is your underlying feature service or map service hosted on ArcGIS Server? Or is a hosted feature service? If it is an ArcGIS Server service, I am assuming the issue is with the number of service instances available. (You have mentioned that the data is accessible and there are no network issues.)
Yep, I'm having this same issue right now! In fact, I just finished configuring the dashboard just yesterday, and everything was working just fine!
I have 2 dashboards that reference the same hosted table data, so I don't want to re-configure 2 dashboards. I tested the hosted table service in a new dashboard, and the new dashboard/service connection is fine. Something is off with the existing dashboards though. Derek Law, any thoughts on this?
Hello Danielle Papineau,
I assume your data was published as hosted feature services as opposed to traditional server-based services. Also, were there any schema changes to the underlying table such as, but not limited to:
As schema changes tend to break dashboards because the Elements might not be able to "find" the fields.
Regards,
Kanin
Hi Kanin Sangcharoenvanakul,
I uploaded a csv, then published the hosted table from that. The hosted table gets updated occasionally by overwriting the data with a new csv (named the same and with the same schema), but wasn't updated since I was configuring the dashboard yesterday. (I should also note that the csv is output via a script, so its schema never changes.)
Another odd thing to mention.... Kanin Sangcharoenvanakul
When I try to access the hosted table details page from the dashboard (via element > select layer), the page opens. When I click on the Data tab, the table does not populate and I set a "There was an error" message.
So I overwrote the data (update data > overwrite entire layer), and pointed to the csv file. Overwrite was successful; I can see data via the Data tab. I can add this to a new dashboard, configure a new element, and everything works fine. But then I navigate to the Data tab again (via element > select layer > info, on the new dashboard), and now get the same error message in AGOL. I cancel out of that configuration, refresh the dashboard, and now the element is Not Fully Configured again.
I can also bring the hosted table into a web map and see data in the attribute table, but can't see the data in the item details > data tab. Kanin Sangcharoenvanakul
thanks Danielle, but it is the 'happening again part' that I decided to hunt for a lasting solution on this forum...
Hi Pianos,
> .. it is the 'happening again part' that I decided to hunt for a lasting solution on this forum...
Please contact esri Tech Support so they can help you investigate the issue further.
Have you verified that all of the services supporting those widgets are using HTTPS and not HTTP?
Yes. The dashboard is only using one service and it is https.
Do you see the not fully configured text if you view/edit the dashboard in firefox? Several dashboards have exhibited that behavior for me previously in Chrome but when viewed in Firefox they worked fine (have seen this with publicly shared ArcGIS Insights workbooks as well).
Hope the issue is resolved soon for you.
I'm having a similar problem. Would changing just the field alias have an affect on its ability to "find" the field?
