Hi Xander Bakker I have used this script and got two rasters "correlation" and "pearson". Which one is the P-value?
Branched from https://community.esri.com/thread/200534-re-correlation-between-two-different-rasters
Hi margarita stevia ,
Could you validate if this works for you? I will create the additional p-value raster and a mask raster containing the pixels with value 1 where the condition (p-value <= 0.05 and positive correlation) is met. The calculation of the p-value is based on the code provided by Dan Patterson
It seems that the resulting areas (blue pixels) are near the rivers . Does that make sense?
See code below:
<SPAN class="keyword token">def</SPAN> <SPAN class="token function">main</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">"load modules..."</SPAN> <SPAN class="keyword token">import</SPAN> arcpy arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>overwriteOutput <SPAN class="operator token">=</SPAN> <SPAN class="token boolean">True</SPAN> <SPAN class="keyword token">import</SPAN> numpy <SPAN class="keyword token">as</SPAN> np template1 <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:\GeoNet\Pvalue\Send\NDVI\r{0}_WUE.TIF'</SPAN> template2 <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:\GeoNet\Pvalue\Send\temp\r{0}_TEM.TIF'</SPAN> nodata <SPAN class="operator token">=</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">3.4028235e+38</SPAN> out_ras_corr <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:\GeoNet\Pvalue\Send\Results\correlation_v01.TIF'</SPAN> out_ras_pear <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:\GeoNet\Pvalue\Send\Results\pearson_v01.TIF'</SPAN> out_ras_pval <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:\GeoNet\Pvalue\Send\Results\pvalue_v01.TIF'</SPAN> out_ras_mask <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:\GeoNet\Pvalue\Send\Results\mask_v01.TIF'</SPAN> <SPAN class="comment token"># settings</SPAN> max_pval <SPAN class="operator token">=</SPAN> <SPAN class="number token">0.05</SPAN> min_corr <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN> mask_val <SPAN class="operator token">=</SPAN> <SPAN class="number token">1</SPAN> no_mask_val <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">"create nested numpy array list..."</SPAN> lst_np_ras <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">for</SPAN> i <SPAN class="keyword token">in</SPAN> range<SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">5</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> ras_path1 <SPAN class="operator token">=</SPAN> template1<SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"%03d"</SPAN> <SPAN class="operator token">%</SPAN> <SPAN class="punctuation token">(</SPAN>i<SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">" - "</SPAN><SPAN class="punctuation token">,</SPAN> ras_path1 ras_np1 <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>RasterToNumPyArray<SPAN class="punctuation token">(</SPAN>ras_path1<SPAN class="punctuation token">)</SPAN> ras_path2 <SPAN class="operator token">=</SPAN> template2<SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"%03d"</SPAN> <SPAN class="operator token">%</SPAN> <SPAN class="punctuation token">(</SPAN>i<SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">" - "</SPAN><SPAN class="punctuation token">,</SPAN> ras_path2 ras_np2 <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>RasterToNumPyArray<SPAN class="punctuation token">(</SPAN>ras_path2<SPAN class="punctuation token">)</SPAN> lst_np_ras<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>ras_np1<SPAN class="punctuation token">,</SPAN> ras_np2<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">"read props numpy raster..."</SPAN> ras_np <SPAN class="operator token">=</SPAN> lst_np_ras<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="comment token"># take first numpy array from list</SPAN> rows <SPAN class="operator token">=</SPAN> ras_np<SPAN class="punctuation token">.</SPAN>shape<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> cols <SPAN class="operator token">=</SPAN> ras_np<SPAN class="punctuation token">.</SPAN>shape<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">" - rows:"</SPAN><SPAN class="punctuation token">,</SPAN> rows <SPAN class="keyword token">print</SPAN> <SPAN class="string token">" - cols:"</SPAN><SPAN class="punctuation token">,</SPAN> cols <SPAN class="keyword token">print</SPAN> <SPAN class="string token">"create output numpy array..."</SPAN> ras_path <SPAN class="operator token">=</SPAN> template1<SPAN class="punctuation token">.</SPAN>format<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"%03d"</SPAN> <SPAN class="operator token">%</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> raster <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Raster<SPAN class="punctuation token">(</SPAN>ras_path<SPAN class="punctuation token">)</SPAN> ras_np_res_corr <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>ndarray<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>rows<SPAN class="punctuation token">,</SPAN> cols<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> ras_np_res_pear <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>ndarray<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>rows<SPAN class="punctuation token">,</SPAN> cols<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> ras_np_res_pval <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>ndarray<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>rows<SPAN class="punctuation token">,</SPAN> cols<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> ras_np_res_mask <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>ndarray<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>rows<SPAN class="punctuation token">,</SPAN> cols<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">" - out rows:"</SPAN><SPAN class="punctuation token">,</SPAN> ras_np_res_corr<SPAN class="punctuation token">.</SPAN>shape<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">" - out cols:"</SPAN><SPAN class="punctuation token">,</SPAN> ras_np_res_corr<SPAN class="punctuation token">.</SPAN>shape<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">"loop through pixels..."</SPAN> pix_cnt <SPAN class="operator token">=</SPAN> <SPAN class="number token">0</SPAN> <SPAN class="keyword token">for</SPAN> row <SPAN class="keyword token">in</SPAN> range<SPAN class="punctuation token">(</SPAN>rows<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">for</SPAN> col <SPAN class="keyword token">in</SPAN> range<SPAN class="punctuation token">(</SPAN>cols<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> pix_cnt <SPAN class="operator token">+=</SPAN> <SPAN class="number token">1</SPAN> <SPAN class="keyword token">if</SPAN> pix_cnt <SPAN class="operator token">%</SPAN> <SPAN class="number token">5000</SPAN> <SPAN class="operator token">==</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">" - row:"</SPAN><SPAN class="punctuation token">,</SPAN> row<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">" col:"</SPAN><SPAN class="punctuation token">,</SPAN> col<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">" pixel:"</SPAN><SPAN class="punctuation token">,</SPAN> pix_cnt lst_vals1 <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN> lst_vals2 <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">for</SPAN> lst_pars <SPAN class="keyword token">in</SPAN> lst_np_ras<SPAN class="punctuation token">:</SPAN> lst_vals1<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>lst_pars<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN>row<SPAN class="punctuation token">,</SPAN> col<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> lst_vals2<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>lst_pars<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN>row<SPAN class="punctuation token">,</SPAN> col<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> lst_vals1 <SPAN class="operator token">=</SPAN> ReplaceNoData<SPAN class="punctuation token">(</SPAN>lst_vals1<SPAN class="punctuation token">,</SPAN> nodata<SPAN class="punctuation token">)</SPAN> lst_vals2 <SPAN class="operator token">=</SPAN> ReplaceNoData<SPAN class="punctuation token">(</SPAN>lst_vals2<SPAN class="punctuation token">,</SPAN> nodata<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># perform calculation on list</SPAN> correlation <SPAN class="operator token">=</SPAN> CalculateCorrelation<SPAN class="punctuation token">(</SPAN>lst_vals1<SPAN class="punctuation token">,</SPAN> lst_vals2<SPAN class="punctuation token">,</SPAN> nodata<SPAN class="punctuation token">)</SPAN> ras_np_res_corr<SPAN class="punctuation token">[</SPAN>row<SPAN class="punctuation token">,</SPAN> col<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> correlation pearson <SPAN class="operator token">=</SPAN> CalculatePearsons<SPAN class="punctuation token">(</SPAN>lst_vals1<SPAN class="punctuation token">,</SPAN> lst_vals2<SPAN class="punctuation token">,</SPAN> nodata<SPAN class="punctuation token">)</SPAN> ras_np_res_pear<SPAN class="punctuation token">[</SPAN>row<SPAN class="punctuation token">,</SPAN> col<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> pearson pvalue <SPAN class="operator token">=</SPAN> CalculatePvalue<SPAN class="punctuation token">(</SPAN>lst_vals1<SPAN class="punctuation token">,</SPAN> lst_vals2<SPAN class="punctuation token">,</SPAN> nodata<SPAN class="punctuation token">)</SPAN> ras_np_res_pval<SPAN class="punctuation token">[</SPAN>row<SPAN class="punctuation token">,</SPAN> col<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> pvalue <SPAN class="comment token"># compare correlation and p-value</SPAN> <SPAN class="keyword token">if</SPAN> pvalue <SPAN class="operator token">==</SPAN> nodata<SPAN class="punctuation token">:</SPAN> mask <SPAN class="operator token">=</SPAN> nodata <SPAN class="keyword token">elif</SPAN> <SPAN class="punctuation token">(</SPAN>correlation <SPAN class="operator token">>=</SPAN> min_corr<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">and</SPAN> <SPAN class="punctuation token">(</SPAN>pvalue <SPAN class="operator token"><=</SPAN> max_pval<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> mask <SPAN class="operator token">=</SPAN> mask_val <SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN> mask <SPAN class="operator token">=</SPAN> no_mask_val ras_np_res_mask<SPAN class="punctuation token">[</SPAN>row<SPAN class="punctuation token">,</SPAN> col<SPAN class="punctuation token">]</SPAN> <SPAN class="operator token">=</SPAN> mask <SPAN class="keyword token">except</SPAN> Exception <SPAN class="keyword token">as</SPAN> e<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">"ERR:"</SPAN><SPAN class="punctuation token">,</SPAN> e <SPAN class="keyword token">print</SPAN> <SPAN class="string token">" - row:"</SPAN><SPAN class="punctuation token">,</SPAN> row<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">" col:"</SPAN><SPAN class="punctuation token">,</SPAN> col<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">" pixel:"</SPAN><SPAN class="punctuation token">,</SPAN> pix_cnt <SPAN class="keyword token">print</SPAN> <SPAN class="string token">" - lst_vals1:"</SPAN><SPAN class="punctuation token">,</SPAN> lst_vals1 <SPAN class="keyword token">print</SPAN> <SPAN class="string token">" - lst_vals2:"</SPAN><SPAN class="punctuation token">,</SPAN> lst_vals2 pnt <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>Point<SPAN class="punctuation token">(</SPAN>raster<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">.</SPAN>XMin<SPAN class="punctuation token">,</SPAN> raster<SPAN class="punctuation token">.</SPAN>extent<SPAN class="punctuation token">.</SPAN>YMin<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># - raster.meanCellHeight</SPAN> xcellsize <SPAN class="operator token">=</SPAN> raster<SPAN class="punctuation token">.</SPAN>meanCellWidth ycellsize <SPAN class="operator token">=</SPAN> raster<SPAN class="punctuation token">.</SPAN>meanCellHeight <SPAN class="keyword token">print</SPAN> <SPAN class="string token">"Write output rasters..."</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">" - "</SPAN><SPAN class="punctuation token">,</SPAN> out_ras_corr ras_res_corr <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>NumPyArrayToRaster<SPAN class="punctuation token">(</SPAN>ras_np_res_corr<SPAN class="punctuation token">,</SPAN> lower_left_corner<SPAN class="operator token">=</SPAN>pnt<SPAN class="punctuation token">,</SPAN> x_cell_size<SPAN class="operator token">=</SPAN>xcellsize<SPAN class="punctuation token">,</SPAN> y_cell_size<SPAN class="operator token">=</SPAN>ycellsize<SPAN class="punctuation token">,</SPAN> value_to_nodata<SPAN class="operator token">=</SPAN>nodata<SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>CopyRaster_management<SPAN class="punctuation token">(</SPAN>ras_res_corr<SPAN class="punctuation token">,</SPAN> out_ras_corr<SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>DefineProjection_management<SPAN class="punctuation token">(</SPAN>in_dataset<SPAN class="operator token">=</SPAN>out_ras_corr<SPAN class="punctuation token">,</SPAN> coor_system<SPAN class="operator token">=</SPAN><SPAN class="string token">"GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">" - "</SPAN><SPAN class="punctuation token">,</SPAN> out_ras_pear ras_res_pear <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>NumPyArrayToRaster<SPAN class="punctuation token">(</SPAN>ras_np_res_pear<SPAN class="punctuation token">,</SPAN> lower_left_corner<SPAN class="operator token">=</SPAN>pnt<SPAN class="punctuation token">,</SPAN> x_cell_size<SPAN class="operator token">=</SPAN>xcellsize<SPAN class="punctuation token">,</SPAN> y_cell_size<SPAN class="operator token">=</SPAN>ycellsize<SPAN class="punctuation token">,</SPAN> value_to_nodata<SPAN class="operator token">=</SPAN>nodata<SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>CopyRaster_management<SPAN class="punctuation token">(</SPAN>ras_res_pear<SPAN class="punctuation token">,</SPAN> out_ras_pear<SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>DefineProjection_management<SPAN class="punctuation token">(</SPAN>in_dataset<SPAN class="operator token">=</SPAN>out_ras_pear<SPAN class="punctuation token">,</SPAN> coor_system<SPAN class="operator token">=</SPAN><SPAN class="string token">"GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">" - "</SPAN><SPAN class="punctuation token">,</SPAN> out_ras_pval ras_res_pval <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>NumPyArrayToRaster<SPAN class="punctuation token">(</SPAN>ras_np_res_pval<SPAN class="punctuation token">,</SPAN> lower_left_corner<SPAN class="operator token">=</SPAN>pnt<SPAN class="punctuation token">,</SPAN> x_cell_size<SPAN class="operator token">=</SPAN>xcellsize<SPAN class="punctuation token">,</SPAN> y_cell_size<SPAN class="operator token">=</SPAN>ycellsize<SPAN class="punctuation token">,</SPAN> value_to_nodata<SPAN class="operator token">=</SPAN>nodata<SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>CopyRaster_management<SPAN class="punctuation token">(</SPAN>ras_res_pval<SPAN class="punctuation token">,</SPAN> out_ras_pval<SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>DefineProjection_management<SPAN class="punctuation token">(</SPAN>in_dataset<SPAN class="operator token">=</SPAN>out_ras_pval<SPAN class="punctuation token">,</SPAN> coor_system<SPAN class="operator token">=</SPAN><SPAN class="string token">"GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">print</SPAN> <SPAN class="string token">" - "</SPAN><SPAN class="punctuation token">,</SPAN> out_ras_mask ras_res_mask <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>NumPyArrayToRaster<SPAN class="punctuation token">(</SPAN>ras_np_res_mask<SPAN class="punctuation token">,</SPAN> lower_left_corner<SPAN class="operator token">=</SPAN>pnt<SPAN class="punctuation token">,</SPAN> x_cell_size<SPAN class="operator token">=</SPAN>xcellsize<SPAN class="punctuation token">,</SPAN> y_cell_size<SPAN class="operator token">=</SPAN>ycellsize<SPAN class="punctuation token">,</SPAN> value_to_nodata<SPAN class="operator token">=</SPAN>nodata<SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>CopyRaster_management<SPAN class="punctuation token">(</SPAN>ras_res_mask<SPAN class="punctuation token">,</SPAN> out_ras_mask<SPAN class="punctuation token">)</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>DefineProjection_management<SPAN class="punctuation token">(</SPAN>in_dataset<SPAN class="operator token">=</SPAN>out_ras_mask<SPAN class="punctuation token">,</SPAN> coor_system<SPAN class="operator token">=</SPAN><SPAN class="string token">"GEOGCS['GCS_WGS_1984',DATUM['D_WGS_1984',SPHEROID['WGS_1984',6378137.0,298.257223563]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]]"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">def</SPAN> <SPAN class="token function">CalculateCorrelation</SPAN><SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">,</SPAN> b<SPAN class="punctuation token">,</SPAN> nodata<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">import</SPAN> numpy <SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN> coef <SPAN class="operator token">=</SPAN> numpy<SPAN class="punctuation token">.</SPAN>corrcoef<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">,</SPAN>b<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">return</SPAN> coef<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">except</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">return</SPAN> nodata <SPAN class="keyword token">def</SPAN> <SPAN class="token function">ReplaceNoData</SPAN><SPAN class="punctuation token">(</SPAN>lst<SPAN class="punctuation token">,</SPAN> nodata<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> res <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="keyword token">for</SPAN> a <SPAN class="keyword token">in</SPAN> lst<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">if</SPAN> a <SPAN class="operator token"><</SPAN> nodata <SPAN class="operator token">/</SPAN> <SPAN class="number token">2.0</SPAN><SPAN class="punctuation token">:</SPAN> res<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>None<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">else</SPAN><SPAN class="punctuation token">:</SPAN> res<SPAN class="punctuation token">.</SPAN>append<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">return</SPAN> res <SPAN class="keyword token">def</SPAN> <SPAN class="token function">CalculatePearsons</SPAN><SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">,</SPAN> b<SPAN class="punctuation token">,</SPAN> nodata<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">import</SPAN> numpy <SPAN class="keyword token">as</SPAN> np <SPAN class="keyword token">from</SPAN> scipy<SPAN class="punctuation token">.</SPAN>stats <SPAN class="keyword token">import</SPAN> pearsonr <SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN> x <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>array<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">)</SPAN> y <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>array<SPAN class="punctuation token">(</SPAN>b<SPAN class="punctuation token">)</SPAN> r<SPAN class="punctuation token">,</SPAN> p <SPAN class="operator token">=</SPAN> pearsonr<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">,</SPAN> y<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">return</SPAN> p <SPAN class="keyword token">except</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">return</SPAN> nodata <SPAN class="keyword token">def</SPAN> <SPAN class="token function">CalculatePvalue</SPAN><SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">,</SPAN> b<SPAN class="punctuation token">,</SPAN> nodata<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">import</SPAN> numpy <SPAN class="keyword token">as</SPAN> np <SPAN class="keyword token">from</SPAN> scipy<SPAN class="punctuation token">.</SPAN>stats <SPAN class="keyword token">import</SPAN> stats <SPAN class="keyword token">try</SPAN><SPAN class="punctuation token">:</SPAN> x <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>array<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">)</SPAN> y <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>array<SPAN class="punctuation token">(</SPAN>b<SPAN class="punctuation token">)</SPAN> r<SPAN class="punctuation token">,</SPAN> p_val <SPAN class="operator token">=</SPAN> stats<SPAN class="punctuation token">.</SPAN>pearsonr<SPAN class="punctuation token">(</SPAN>x<SPAN class="punctuation token">,</SPAN> y<SPAN class="punctuation token">)</SPAN> <SPAN class="keyword token">return</SPAN> p_val <SPAN class="keyword token">except</SPAN><SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">return</SPAN> nodata <SPAN class="keyword token">if</SPAN> __name__ <SPAN class="operator token">==</SPAN> <SPAN class="string token">'__main__'</SPAN><SPAN class="punctuation token">:</SPAN> main<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
Neither, p-value is a measure of the strength of the correlation coefficient calculated from sample size and the measured 'r' and a sampling distribution
scipy.stats.pearsonr — SciPy v1.3.0 Reference Guide
example for variants of simple arrays, using this
<SPAN class="keyword token">from</SPAN> scipy <SPAN class="keyword token">import</SPAN> stats a <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>arange<SPAN class="punctuation token">(</SPAN><SPAN class="number token">9</SPAN><SPAN class="punctuation token">)</SPAN> b <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>arange<SPAN class="punctuation token">(</SPAN><SPAN class="number token">9</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">)</SPAN> c <SPAN class="operator token">=</SPAN> np<SPAN class="punctuation token">.</SPAN>array<SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">9</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">7</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">8</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">6</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">5</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">4</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">3</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># ---- like b, but 2 numbers switched</SPAN> r<SPAN class="punctuation token">,</SPAN> p_val <SPAN class="operator token">=</SPAN> stats<SPAN class="punctuation token">.</SPAN>pearsonr<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">,</SPAN> b<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token"># ---- perfect inverse, r = -1, p = 0.0000</SPAN> r<SPAN class="punctuation token">,</SPAN> p_val <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">1.0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.0</SPAN><SPAN class="punctuation token">)</SPAN> r<SPAN class="punctuation token">,</SPAN> p_val <SPAN class="operator token">=</SPAN> stats<SPAN class="punctuation token">.</SPAN>pearsonr<SPAN class="punctuation token">(</SPAN>a<SPAN class="punctuation token">,</SPAN> c<SPAN class="punctuation token">)</SPAN> r<SPAN class="punctuation token">,</SPAN> p_val <SPAN class="punctuation token">(</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">0.9833333333333333</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">1.936196303745927e-06</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
I want to extract the pixels where correlation is positive and p-value is < 0.05 How i can do that? How i can estimate P as a raster?
Hi Xander Bakker please help me with how i can extract correlation values at 0.05 significance level. I'm running out of time.
Hi margaritastevia
Can you share a sample of your data and the script you have so far?
Hi Xander Bakker,
Thank you very much for your kind response. please find the attachment.
print("Thank you")
Thank you Sir Xander Bakker. I'm vary thankful to you for your kind response. The script is running perfectly. Yes the pixels are near the river.
