Greetings Everyone,
I have a vector tile draped over ground elevation in a WebScene (Scene Viewer ). It looks great when I design it in the Vector Tile Style Editor (ArcGIS Vector Tile Style Editor (beta) ) . However, in the Web Scene the labels are so small. I can barely ever read the labels and I designed the vector tiles with the 'large label' option. Has anyone ever dealt with this before and solved it? Do you know what multiplier to use on all the labels in the WebScene? Any recommendations will be greatly appreciated.
Tyler
That was it. I don't believe that the optimization settings have an effect on the font size. To change the font size I went back to the ArcGIS Vector Tile Style Editor (beta) and edited my vector tile layer. In the style editor click the 'Edit Layer Styles' menu and hammer away. Lots of clicking but the outcome looks great. It would be awesome to be able to output the JSON file and edit it in a text editor.
Russell Roberts
Can you share the vector tile layer you styled and are seeing this issue with?
Thanks!
Hi Russel, Here is the link: Scene Viewer
Hi Russell Roberts, Here is the link: Scene Viewer . Is there anything else that you need? Any ideas or suggestions will be greatly appreciated.
Thanks, Tyler
I couldn't really see a difference between scene viewer and map viewer, What do you have the optimization setting set to performance vs. quality?
Hi Russell Roberts, the performance -vs- quality slider was set in the middle. I moved it to 'performance' and saved but there is no difference in the application that I consume the scene in. Is there a way to adjust the font size? Thanks for your help. Tyler
My map application
ArcGISOnline WebScene
Can you check under the settings what you have the Scene Viewer graphics optimization set to? Also what browser and device are you viewing the scene in?
