I need to increase the size of the applications popups. I am not finding the same skins I had used in the 2.5 viewer to perform this function previously in the arcgis-samples-flex-3.6-src folder.
Christina,
The PopUpRendererSkin.mxml is included in the Flex API download under the ArcGIS_Flex\src\com\esri\ags\skins folder.
Hi Christina,
You could use ArcGIS API for Flex. The PopUpRendererSkin.mxml might be available in arcgis_api_for_flex_3_6\ArcGIS_Flex\skins\src\com\esri\ags\skins\ folder of the API download.Check the solution by Robert Scheitlin, GISP in the following link:
Modifying the Popup Window in ArcGIS Viewer for Flex v. 3 Pre-release
Found it. I think I was looking at it too long. Too easy. Thanks
I have increased the size of the popup easily. Thanks for the tip. However, I am wondering what file contains the swf when i move it to production? is this the index file?
Yes any mxml that is not a module with just be compiled into the index.swf
Thank You
