When I run my program in a VM, it fails to render a map, I see the 'powered by ESRI' logo in the bottom right,
just the map area is blank(white).
No errors in the log, shows:
Rendering engine: DirectX
Runs fine outside of a VM.
Could you try the solution at ArcGIS Runtime SDK for Java and Virtualization
OK, so I think I've figured out what caused the problem. If I use the 3d acceleration mechanism offered by VMs the rendering doesn't work, however if the acceleration is turned off it works flawlessly.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
