I have created a survey123 and now I downloaded the survey to my tablet using the app, I open it and it open but the screen is blank only color that use for the back ground show.
Are you signed into AGOL, Enterprise, (in the S123 field app itself) or whatever portal the survey is hosted on? Are you using the S123 field app or a browser?
I have AGOL I created the survey with new version of the survey where you can split the page in two to have question side by side. It works good when I open the survey from the web, but when i open it using the app their is where it open to a blank page. I did a test survey using the split page and one the single page and the one that is split don't open with the app but the single page open with the app. My conclusion is that using the split page has bug using the app.
Hello @ArthurMartinez,
Did you author the survey in the Survey123 web designer or Survey123 Connect (desktop application)?
I’m having the same issue. I created my survey in Survey123 browser
Very annoying, I am experiencing this, too. Why make the split an option if it doesn't work on other devices??/
I use Survey123 web designer.
