hi,
I am creating a survey in Survey 123 Connect and would like to
set the 'note type' question not hidden in the print out. Any help on this?
thanks
First suggestion? Don't. Just hard-code the note into the print-out. A "note" is just text, so toss that text into your Feature Report.
If you are dead-set on doing this, you could try giving the note something in the [name] column, and then referencing that [name] in the output (NOTE, the "note" question type does not require anything in the [name] column. But if you give it a [name], that note will be added to the Feature Layer). Honestly, not sure if that is even supported as it is kind of redundant to do so (see by first suggestion).
Thanks
