How do you create a table-list within a group with a bunch of questions that share a select_one question, like in the screenshot below?
It's called a single select grid now I think. You use table-list appearance
See here https://doc.arcgis.com/en/survey123/browser/create-surveys/quickreferencecreatesurveys.htm#ESRI_SECTION2_F2B89F478189425F9451C6B626E11BAF
It was hard to find for some reason. Hope that helps
One caveat is that you can't have a conditional question right after the select question. For example, if a user selected 'Dislike' above, you may want a text question to display asking for details about what they didn't like. While you can have these outside the table-list, you can't have them directly after the select question.
Hello,
In Survey123 Connect, I want to use the hint and guidance_hint, but they are not configured on the correct lines. Instead of appearing below the question they are configured for, they appear above it.Could this be an error?
Thank youBest regards,
João Fernandes
@jcfernandes I'm looking for something approach in my survey123Can you share the sample template of this , So that i can approach
I shall be thankful to you
