Configuration:
Windows 10 Pro
Version 22H2
Os Build 19045.3393
tried to import library from python command prompt, getting the error:
(arcgispro-py3) C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3>python
Python 3.9.16 [MSC v.1931 64 bit (AMD64)] :: Anaconda, Inc. on win32
Type "help", "copyright", "credits" or "license" for more information.
>>> import arcpy
File "<stdin>", line 1, in <module>
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\__init__.py", line 77, in <module>
from arcpy.geoprocessing import gp
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\__init__.py", line 14, in <module>
from ._base import *
File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 14, in <module>
import arcgisscripting
File "C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\lib\site-packages\arcgisscripting\__init__.py", line 131, in <module>
from ._arcgisscripting import *
ImportError: DLL load failed while importing _arcgisscripting: The specified procedure could not be found.
follow DarrenConly instructions without success:
https://community.esri.com/t5/arcgis-pro-questions/importerror-dll-load-failed-while-importing/m-p/1295489#M69800
Tried many solution found on web...
added to global environment variable "PATH":
C:\Program Files\ArcGIS\Pro\bin\Python\envs\arcgispro-py3\Lib\site-packages\arcgisscripting
C:\Program Files\ArcGIS\Pro\bin\Python\Scripts
added to global environment variable "PYTHONPATH":
Clear installation
No Arcmap Installed
No QGis Installed
No other python environment installed
No VScode or other IDE installed
Unable to create cloned workspace (with arcgis or conda command prompt)
I don't know how to solve...
thanks in advance
