Hi there,
I am looking to see if it is possible to upload more than one photo at a time to a point when adding from device files/photo library. I have tried a few different things and nothing seems to yield the results I need.
Thanks!
Hi @SamuelSchneider
Thanks for your question. I believe this functionality has already been implemented in Field Maps and should already be available for you (Select and Attach Multiple Photos at Once in Field... - Esri Community). I have just tested this out myself and have been able to upload multiple photos for one point.
Perhaps you need to update the version of Field Maps that you are using? If this still doesn't work for you, could you please let me know what device you are using and your version of Field Maps?
Issy
You are correct it was just an update thank you!
Do you know if the same is possible in a web app via ArcGIS Enterprise portal?
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und vieles mehr. Neu hier? Erstelle ein kostenloses Konto.
