ArcGIS Online has a usage tab in the item details page. We have Enterprise Portal and this tab is not showing on the item details page. Is it part of portal now and how do I turn it on. If not part of Portal will it be added in future releases?
Hi Nita,
Please see this help topic,
Work with usage reports—Portal for ArcGIS (10.6) | ArcGIS Enterprise
Hope this helps,
Thanks for the information. I think this will work until ESRI decides to add the usage tab to Enterprise Portal.
Hi Derek,
I appreciate your responding to Nita's message. I have the same question as she did, and I've looked at the link you sent, but it really doesn't do what I need it to do because I've found the usage stats to be completely inaccurate. For instance, I know something was viewed yesterday. I was standing over someone's shoulder when they opened it and used it. I, too, opened and used it yesterday. Yet, it doesn't even show up as an item in the "Content Details" when I look for the last 3 days (I did 3 days just to give it a buffer, and there are no other filters set other than the dates at the top).
Really, the way AGOL had it set up in the Item Details was just fine and seemed to provide accurate information. Having accurate usage feedback the way it exists on AGOL is critically important, and since it already exists in AGOL, I can't understand why the Portal would not offer it. Are there any other options? Is this at least on the road map for future Portal updates? Thanks for you help!
Hi Lindsay,
Sorry for the late reply.
What release of Portal for ArcGIS (aka. ArcGIS Enterprise) are you using? FYI, the functionality in Portal may be slightly "behind" ArcGIS Online and this might be a known issue that was fixed in ArcGIS Online, but not in your Portal release (yet).
10.7.1
Lindsay Maier
Crime & Intelligence Analyst
Crime Analysis Unit
St. Louis Metropolitan Police Department
Email: lhmaier@slmpd.org
Phone: 314-444-5945
@DerekLaw any ideas when the Usage tab will be coming to Portal? We've been waiting for this for a few years now. Or are there other free tools out there that can generate the usage graph that AGOL displays?
The Usage tab in AGO is so helpful. Really need it it Portal.
If I have an old map or feature layer I am considering deleting, quickly and easily knowing the Usage is helpful. With the Usage Tab in AGO this can be done in seconds.
Otherwise it's a best guess
You could adjust the code base of this tool AGOL-MetaData Snagger to lookup the view count daily and subtract from the previous day, and store it. You would get something that looked like this...
Then you could take that date and generate up metrics that start looking like this....
Which will turn into dashboards, etc.
I agree...the Usage tab is a very very useful tool and should be put into Portal. Frankly, the closer the code base for Portal and AGOL is, the better for most of us because we would not have to reinvent the wheel for what are essentially the same systems configured slightly different.
Hey @DerekLaw is there any update on this? Will the "Usage" tab be added to Portal anytime soon? Thanks!
Not to beat on a dead horse, but it would be good to upvote this idea to hopefully promote this:
https://community.esri.com/t5/arcgis-enterprise-ideas/portal-item-usage-can-we-please-get-the-agol-usage/idi-p/1155009
