When my users try to edit a record from their Sent folder, some of the fields show up as blank. They definitely weren't blank when they were submitted because they are required fields. Those fields have values in the feature layer also. The fields that show up as blank when editing from sent folder also all have a choice filter. However, not all fields in the survey with a choice filter are having this issue. Anyone else run into this? Any ideas on how to rectify? Thanks! @DougBrowning @ZacharySutherby @IsmaelChivite
Hello @JamesKelly6,
Would you be able to pass along your XLSForm with the questions experiencing the issue highlighted?
@ZacharySutherby see attached. The stream and processor questions are where I am experiencing this issue. Thanks in advance for any insight you can offer!
I noticed your bind::esri:parameters column is empty. Have you tried setting query allowUpdates=true
Also, you have duplicates in the name column. I assume you are only adding those to End Group or End Repeat, but I didn't check in detail. I would advice that you ensure all fields have a unique name. If you didn't know, you can leave the name column empty for End Group and End Repeat (and Note), which is what I'd suggest (but to each their own).
Edit: I will add a couple more things that noticed in a quick scan:
@ZacharySutherby any insights here?
@ZacharySutherby just following up to see if you have been able to take a look at my xlsform?
