Here is an existing post about this but in the ArcGIS Pro community, same issue, I tried the suggestion to clear my cache but no go https://community.esri.com/t5/arcgis-pro-questions/deleting-text-space-in-storymaps/td-p/1086481
I am unable to delete this empty space in my text box and it looks unprofessional. This should be really simple but I am unable to figure out how to delete this empty space? Anyone?
@BrittanyBurson - I'm sorry you've run into an issue with extra space. I ran into this once and resolved it by dragging the blocks below the space to a position above it. This rearranged the blocks and pushed the space out from between the blocks.
All blocks have a drag handle on the left when you hover over them. Just grab the block and drag it to relocate.
Can you give that a try and let us know if that works for you?
Pressing Delete or Backspace on my keyboard doesn't remove the box. As Brittany has said, just dragging the box out the way isn't a solution. Is there any progress on this bug?
Are you on AGOL? I'm running ArcGIS Enterprise 11.3 and it doesn't look like the delete option is available. I suppose it's a new addition in 11.4 or 11.5 (?)
Even if it's late, or maybe you've already figured it out — but just in case, you can click on the text box and just press delete. That will remove them.
This will just move the extra space. Is there a way to actually delete the space. I have 6 headings to delete.
I saw this was marked as an Accepted Solution... just want to follow up reply that it's a workaround rather than a solution... should still be fixed as it's not user friendly.
@OwenGeo that worked, thank you very much for the reply.
