We succesfully implemented a drone, first person and a VR camera inside Unreal 5.02 together with ArcGIS SDK for Unreal (didn't update to the release version yet). When you setup a project on one side of the globe (in this case the Netherlands) everything works great and can switch between all the different cameras (see screenshots globe 1 and globe 2).
Then when we setup a project in the US (California) then hit play you fall down and see slide around the globe down:). See the images.
Am I missing something? Or is there a setting to fix this problem?
Thanks in advance
Were you considering updating to the release version soon? It is a bit easier to communicate about these things in this case. When you update the camera position could you also try updating the map's origin position to be in the same part of the world? This should update it so that the normalized vector to the earth is pointing up
Hi Matt,
Thanks for the fast reply. Hopefully this weekend because we were in the middle of some development and were afraid to break stuff:).
We will check this suggestion.
Sounds good, keep us posted
Do you have large worlds enabled?
Yes that is enabled and upgraded to 1.0.0 finally. Testing the sliding issue and will post our results.
I think we solved the sliding issue doing this.
As always, thank you for your help.
When we use the solution as shown up we face another problem. Even when we change the map origin when switching between projects the UE coordinates of the corresponding map actor remain the same.
When we add a 3d object in 1 place and then switch to a complete different location the same objects appear on that location too.
I think we found the issue with the objects but need to understand one 1 more thing before implementing this.
When we add a cube, add a ArcGISLocation component to the cube and place it in the location we want everything works great. Even switching between locations, we don't have the problem as described above.
Because if we don't add this component to our object the same object will appear in every location around the globe. If we add this component it will show only where you place and add the ArcGISLocation component.
Maybe I am missing something?
If you are going to be changing the Map's origin you will need to attach a location component. That is how we anchor objects to real world positions in the world. I am not sure I understand if you are having a problem with that.
I understand the arc gis location component but it is really tedious to add this component to each seperate object of your model. We import BIM models and they consist of hundreds of seperate objects and as far as we know that Unreal doesn't allow to add a component to multi selected objects. It will take forever to do this each time for each of the model you import. The arc gis location component sometimes has strange behaviours. Sometimes it rescales the object when you add this component. Fast and easy example: Try adding a box, scale to make a rectangle and then add an arc gis location component. It resets the box and makes it smaller. I can record a video if it is not clear.
