Hello,
Can anyone help me out...I have a list of values in my Survey where you can only pick one response. What I would like to do is have a default value populate if that question is skipped. Basically I would like to have a "None or N/A" as a default response to that question. I have added that to the default question in the survey, but it did not work. I am not using data from an outside source or a csv or anything...just my Excel form from Survey123. This is all kind of new to me.
Any help will be greatly appreciated. These are some snap shots of what my data looks like. (see attached)
thanks
Larisa
Hmmm, I have never used that particular workflow of linking the surveys like that. Is that question in both surveys? If so, maybe the options from the choice list have to be identical?
Hmmm, I've done this many times in surveys myself and haven't had an issue. What version of Survey123 Connect are you authoring this survey with?
Also, I think having it in the default cell without quotes should be correct, but have you tried putting it in quotes to see if that changes it?
Also, what appearance do you have for each of the select_one questions?
HI Katherine,
thank you for getting back to me. I am using version 3.12.232. I think this issue could be due to the fact that this survey is an "authoritative survey", that is, if I change the results in this one it changes results in another. I am using this survey to edit another....from what I have read and done before...this should not be an issue. However, I have not done this exact thing before.
yes the question is in both surveys, but hidden in the "customer" survey. one that customer survey has been completed, I can access the "authoritative survey" and answer the two questions . and you might be right...I need to match it in both surveys. I did not think about that. I will try that.
Katherine.... thank you, that was the issue. I had to add the default value to the original customer survey...even though it was hidden. I just figured that hidden meant just that. silly thing for me to overlook, but thank you for making me think a little more!
Wonderful, glad it's working now! 🙂
