I wanted to know if it is possible to add the imagery basemap (as a mobile scene package or something else) and then take it offline in ArcGIS Earth.
I opened the tpk with 7zip and if you go into the v101/Layers folders you'll see the conf.xml. There you will find the scale for LevelID 17. I confirmed the levels by going into the _alllayers folder to see that the highest LOD was L17. If you were in another region with more LODs you would see more levels but in this region the highest is 17 which I also confirmed by comparing the TPK to the basemap.
The easiest way is to use the Download Map option on the Map Tab or Tile Package Kreator (second link).
https://pro.arcgis.com/en/pro-app/help/projects/take-a-map-offline.htm#ESRI_SECTION1_50BF87B39D1046E8BD49EA6B40AD5DAB
https://www.arcgis.com/home/item.html?id=9c9ddae83e5549bb88a2c22e87a18ba1
This will create a tile package. Since the tile package will be in Web Mercator you will need to add that to a basemap and then to a new global scene in order for the Create Mobile Scene Package tool to set the Scene's coordinate system as Web Mercator.
https://pro.arcgis.com/en/pro-app/help/mapping/map-authoring/basemap-and-elevation-sources.htm
https://pro.arcgis.com/en/pro-app/help/mapping/map-authoring/author-a-basemap.htm#ESRI_SECTION1_65A60934882541EFA2130B51B34F9D47
@Andrew Thanks for the response. I am trying to use the "Download Map" option in Pro but the tile package which gets created does not show tiles beyond the 1:5000 scale even if I set the "Max scale for Tile Layers" to 1: 142 (the default). Any way to fix this? I know this is slightly off topic but without maximum available resolution the 3D scene I am creating will not be useful...
Are you trying to take a large area offline? Based on the help it says "Each tile layer has a maximum number of tiles that can be taken offline. If your map covers a large area, the maximum tile limit will be reached at a given scale." so it appears that you are reaching a limit here and one way to verify is zooming in to a smaller area and see if you can get more tiles. I'll reach out to the team that implemented this to confirm.
thanks,
Andrew
Yes - I am trying to take it offline. I tried zooming in on a smaller area but did not see any change. Also, there is no error message to indicate there is a problem...
It's probably best to clarify larger vs smaller...for me I zoomed in on a neighborhood using the World Topographic basemap and was able to take all zoom levels offline. Which basemap are you using? I reached out to the team in charge of this and am still waiting to hear back.
The area is about 7 sq km. I am trying to use the imagery basemap
Thanks for those details. I heard back from our Content Management Team and it looks like for the World Imagery there is a maximum export tile request of 150,000 tiles. This is specified here https://www.arcgis.com/home/item.html?id=226d23f076da478bba4589e7eae95952
They did say that they are looking to add better messaging/error handling when the max tile count is reached. In your case it does seem to me all of it should download for 7sq km. If you want to create a bookmark at the location you are downloading the map and then send me the bookmark I can try on my end. Otherwise the only other recommendation I have is to use an alternative imagery source for example NAIP imagery https://datagateway.nrcs.usda.gov/GDGHome_DirectDownLoad.aspx
A colleague pointed an alternative that may work for you. In the case of utilizing a larger extent with a lower resolution you can edit the conf.xml to ensure the imagery displays at all zoom levels. This is explained in the post below
https://community.esri.com/t5/arcgis-explorer-questions/make-tile-package-tpk-visible-at-all-scales/m-p/767931
Andrew,
Here is the bookmark - please try on your end and let me know.
I was able to create the tpk with all 18 levels.
I opened this up on ArcGIS Pro and I am still not seeing beyond 1:5000.
Am I missing something here?
Nope there's nothing you're missing the max scale for this area is <LevelID>17</LevelID><Scale>4513.9887049999998</Scale> so you won't be able to view past this LOD. If you add this into ArcGIS Earth you will be able to continue to zoom in but the resolution will stay the same.
Thanks 🙂
BTW - how did you find out the maximum scale value?
