I would like to see some additional data management options in the ArcGIS Data Store. I'm currently noticing some data management issues that could probably be easily resolved if Esri provided some additional data management tools.
For example, the size of our ArcGIS Data Store is getting bloated and we have no way to reduce the file size. We host the ArcGIS Data Store on its own VM, but deleting the data from the hosted feature service (such as through ArcGIS Pro) does not actually release data back to the OS.
I would like to see an Esri tool that would actually release the free space back to the OS (usually accomplished by using a Full Vacuum command in PostgreSQL). I understand that deleting records from the tables will release the space back at the table level (usually through the regular vacuum command which appears to be happening, at least according to the ArcGIS Data Store logs), but I would like to extend that further to release it back to the OS. I deleted approximately 100GB worth of photos, but none of that data is being released back to the OS, and our available storage space is still going down because we're still collecting data in other tables. It is not sustainable for us to just continually adding space to the VM. We need to be able release free space back to the OS to make room for other surveys that contain photos.
I have access to the ArcGIS Data Store through pgAdmin, but would prefer to perform these actions using an "Esri approved workflow", such as using an ArcGIS Data Store command utility.
Furthermore, since I do have access to the ArcGIS Data Store through pgAdmin, I am noticing that Esri is not always deleting tables it no longer needs (such as when deleting the hosted feature service in Portal or when updating an existing Survey that requires it to "delete" and re-add the table because it is making a schema change to the survey). It leaves the old tables in the database, and just creates new tables. This is very dirty data management which results in a bloated ArcGIS Data Store which Esri gives us no option to cleanup unless if we modify the ArcGIS Data Store directly through pgAdmin which Esri does not recommend. If there could be some cleanup operation that detected orphaned tables and deleted them, that would be nice.
