Currently the only help I can find on this is a small section in this link. This is a potentially powerful feature in creating custom formatted reports and some extra help in a blog (with examples) would help users make better use of it.
I just found a bit more on the following post
https://community.esri.com/groups/survey123/blog/2018/07/06/bull-release-30
Hi all,
Thanks for your feedbacks.
We have the conditional elements section documented in the help topic now: Feature report templates—Survey123 for ArcGIS | ArcGIS . Did you find it useful?
I'm getting 'generate' errors when use conditional syntax in my Word document like:
Owner: ${SiteTreeOwnership}
Type of Failure: ${TreeFailureType}
${if ${TreeFailureType} == “TF”}
Trunk Failure Height: ${TrunkFailureHeight}
Trunk Failure Diameter: ${TrunkFailureDiameter}
Errors:
Using this documented syntax in Word document...
${if ${TreeFailureType} == “RF”}
Root Failure Type: ${RootFailureType}
${if ${TreeFailureType} == “BF”}
Branch Diameter: ${BranchBreakDiameter}
Branch Length: ${BranchLength}
I get error messages...
Error occurred when checking the report template. The tag beginning with "${TreeFail" is unclosedThe tag beginning with "${# " is unclosedThe tag beginning with "} == “RF”" is unopenedThe tag beginning with "${TreeFail" is unclosedThe tag beginning with "${# " is unclosedThe tag beginning with "} == “TF”" is unopenedThe tag beginning with "${TreeFail" is unclosedThe tag beginning with "${# " is unclosedThe tag beginning with "} == “BF”" is unopenedThe loop with tag "" is unopenedThe loop with tag "" is unopenedThe loop with tag "" is unopened
I determined the syntax error with some trial and error...
This works...
Failure:
${TreeFailureType} [correct syntax outside the if conditional element]
${if TreeFailureType == “Root Failure”} [correct syntax inside for the if conditional element]
Root Failure Type:
${RootFailureType} [correct syntax for referencing the attribute value in the if element]
This doesn't...
Type of Failure: ${TreeFailureType} [correct syntax outside the if conditional element]
${if ${TreeFailureType} == “RF”} [this is NOT correct syntax for referencing the attribute]
Melden Sie sich an, um zu posten, Inhalte zu folgen und mehr. Neu hier? Kostenlos registrieren.
