I have a form using repeat to collect multiple geopoints. Is there a way to display all these geopoints in a form in the same map using the feature report tool?
I would like to have in the final report a single map showing all the location of all points surveyed in that form entry.
I'm using this for a transmission power line inspection. Each entry in the form is a transmission power line, but over the inspection, the user may add multiple inspections points. The report will, then, pull out all the data in a pre-formatted report, and a map showing all the inspection points over the same map.
That is needed because it's not very useful to have each point displayed individually, we want to see the distribution over the area of all points collected on the field.
Thanks!
