Hello!
I have created a javascript function to run in Survey123 Connect based on an example found on ESRI Events YouTube channel (Extending the Survey123 Field App - YouTube ). This function allows an infrastructure zone to be calculated based on the location of the device/selection on the map. It works perfectly in Survey123 Connect, publishes fine and works on the Survey123 App however once I open the survey on the web I get an error:
Error: Initializing form...
Failed to load data from jr://file-csv/@javascript.csv
I have attached a Survey Design folder which is a simple example with which I am having the same issue.
Any help is greatly appreciated! Thank you!
Brandon
