I have a survey with a repeat. In the survey I have a question to know if the survey is cancelled or not. I need to report that information in every repeat. I try a calculate in the repeat to copy the information. But only the first repeat contains the value of the calculate.
I have the same problem with another calculate field (sum) in the repeat the field contains the result of the concatenation of 2 fields from the main survey.
Is there a way to calculate the value for each repeat?
this is the result of the 4 repeats in the same survey.
I joint my xls form
