**Edit** I submitted a case through ESRI Technical Support and the tech thinks this is a bug in version 3.6 of Survey123. If a survey is submitted through the web, the data will be added to the feature layer, but a point will *not* be created. If a survey is submitted through the app, both the data and a point will be created as expected. When testing the web survey with '?version=3.5' at the end of the URL, it worked as expected.
One of my surveys has decided to not create a point whenever a survey is submitted via the web. The data is still entered into the table, but there is no point on the map. I've looked in the Data-Visualization tab on ArcGIS Online, a webmap created with the layer, and the data tab in Survey123 - all with the same problem. The data is there in the table, but there is not a point on the map.
I've submitted to the survey via an Android phone and the data point shows up as expected. No problems.
Anyone have an idea what is going on here?
