Does there exist an integration that allows for a Survey 123 survey to fire off a Maximo work order? Is anyone out there achieving this? Thanks!!
I have been doing this for a while now using python scripts. We are finding lots of value in the offline capabilities of Survey123 and Collector for non critical inspections and problem reports. The geoevent server and python scripts are complex because you have to learn the Maximo REST API (doable, but complex) and it is nowhere as friendly as the enterprise REST. To simplify this My coworkers built a flow based modeler to move data between systems.
Currently there isn't anything within the Survey application itself that will trigger a secondary action. This is doable via GeoEvent Server or DB triggers using a survey tied to your enterprise geodatabase. Having the Survey123 application support after submission actions is a feature that we are planning on in the future.
Angemeldete Mitglieder können Beiträge verfassen, Updates folgen und mehr. Neu hier? Registriere ein kostenloses Konto.
