I've noticed a weird issue when republishing forms that prompt you that it would erase existing data. It looks like instead of overwriting the existing hosted feature layer, multiple host feature layers will be created for the survey, depending on how many times I overwrite the form data:
My problem arises when viewers of the form login into the Survey123 site, they are getting the data from the old version of the form data, while I, as the form owner, see the new data in the Survey123 web interface. Is there a way to redirect their view of the data to the latest version of the feature service without providing them with my login credentials?
I have tried unsharing the old version of the FS which didn't solve the issue. I have also tried manually delete the old version of the FS in ArcPro and AGOL. I was able to delete some versions of the hosted FS, but not the original version which is what is visible to the viewers not using my AGOL credentials.
I know if I publish a new version of the form this issue is resolved, but I was hoping for a less disruptive solution.
