As seen here, it is possible to calculate a geopoint question. But is it possible to calculate and hide a geopoint question?
Currently, if I set Relevent = false to this question, then the location of the survey seems to default to 0°,0° (At least on windows 7 with no geolocation service).
So I then tried to use the "center" URL parameter to populate the geopoint properly as explained here. This work great. The geopoint question can stay hidden and the survey default to the proper location. But this is not a solution for me as my user don't click on a URL everytime they use the survey.
So is it possible to set the "center" parameter from inside the survey?
Basicly what I need is the following:
- Set the geopoint location from inside the survey.
- Make sure no geopoint question is seen in the form.
