I have built a survey on top of an exiting feature service that has Editor Tracking fields enabled (Creator, Creation Date, Editor, Edit Date). I want to be able to add the Creator field into my survey as Read Only, so that the user of the survey can use the field for filtering of the Inbox. I can't seem to figure out how to add the Creator field into the survey and then publish the survey - I keep getting the message that "The custom feature service submission url is not compatible with this survey (Field Creator in myTableName is not editable). How can I add the Creator field into the survey so that it can be used for filtering?
